lincoln welder v300 pro
发表于 2021-8-31 23:21:01 | 显示全部楼层 |阅读模式
Found one for sale and I was wondering if this unit can run a spool gun? Looking to be able to weld the thicker alum. Thanks]Lincoln PT 225 Tig
Reply:Originally Posted by DrichFound one for sale and I was wondering if this unit can run a spool gun? Looking to be able to weld the thicker alum. Thanks
Reply:Be careful, This is an older inverter welder so make sure it works before buying.Some parts are no longer available and some are Real expensive.
Reply:I passed on it as the guy don't know the status of it working or not.]Lincoln PT 225 Tig
GMT+8, 2025-12-27 11:30 , Processed in 0.116077 second(s), 18 queries .
