Center a smaller rod on larger
发表于 2021-8-31 23:20:47 | 显示全部楼层 |阅读模式
I have several projects which require me to attach 1/2" rod to 3/4 and 1" rod.  Does anyone have any secrets to centering these to one another prior to welding?I was thinking of two pieces of angle supporting each piece but then I need to shim the smaller so it is centered.  So far I havent not had success with any of my ideas.  Has anyone done this before?  My head hurts . Attached Images
Reply:Do you have access to a lathe? I would turn the smaller rod down a hair then drill out the center of the lager diameter 1" to accept the smaller...Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:you could take an inch or so thick piece of aluminum or some other semi soft material. pop it in the drill press. Drill it about halfway with the bigger size bit. Then use a center punch of the right diam and punch the bottom (which should already have an indent from the drill bit) then drill out the rest with the smaller bit. You could then cut the top 1/4 of the material off with a bandsaw or angle grinder which would let you nest the 2 rods together and hold them while allowing for a window to tack. The problem is once you final weld the 2 together the whole thing is going to warp.using a piece of angle iron with the right size shim stock on the smaller rod is probably the easiest way, then you can clamp it down to help fight warping.Last edited by chrisbmx68; 07-16-2012 at 01:27 PM.
Reply:See below.    This would be just to hold them centered while you make 3 tack welds. Attached Images
Reply:I'm guessing you don't have a lathe.  Do you have a drill press?  Try taking a thick piece of scrap.  Clamp the scrap to the table.  Drill completely through with the smaller size, then drill halfway through with the larger size without unclamping the workpiece.  Then cut the piece in half across the hole.You can then lay the two rods in this half-circle jig and their centers will be lined up.You might even get away using just a hand drill.  The larger drill should follow the hole of the smaller drill if you're careful.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Hello cromwell, I have included an image which would utilize a length of angle iron and some shims. If you were using 1/2"round and centering it on 1" you would need for the shims to be 1/4" thick, if you were using 3/4" round and centering it on 1" you would need to use 1/8" thick shims. I believe you get the idea. The view that is shown in the image would be looking down from the top. Good luck and best regards, AllanEDIT:Have an additional image to give some orientation and also possibly show some access holes to help with tacking while the rods are being held. The shims, as they appear, would be on the inside of the angel and not as they look in the image. Attached ImagesLast edited by aevald; 07-16-2012 at 05:17 PM.aevald
Reply:Just like aevald said.  Get piece of angle, lay the 3/4'' rod in angle, take a 1/8'' 6010 welding rod and cut in half, knock off coating, bend into a close 90 and lay in angle , take chisel and tap welding rod into bottom of angle, lay 1/2'' rod on top. You can then tack 1/8'' rod to angle to keep it from shifting. For the 1''  try 1/4'' rod.
Reply:Originally Posted by aevaldHello cromwell, I have included an image which would utilize a length of angle iron and some shims. If you were using 1/2"round and centering it on 1" you would need for the shims to be 1/4" thick, if you were using 3/4" round and centering it on 1" you would need to use 1/8" thick shims. I believe you get the idea. The view that is shown in the image would be looking down from the top. Good luck and best regards, Allan
Reply:Not mentioned, but probably assumed by Allen and the others, is that you also need to shim the rest of the bar material at some point, so it stays straight. If not that angle iron will tip up the connection and while it may be "centered" at the joint, it won't be centered and straight.If you simply support the 1/2" with a length of 3/16" angle and the 3/4" with a piece of 1/4" angle, and make sure they line up ( the real trick), you kill 2 birds with one stone..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Very good point DSW, the longer you can make the angle and the shims the better the accuracy of the centering. Regards, AllanEDIT: couldn't edit my other post again so I'll try to include an updated image here. This might better explain what Doug was referring to and I was agreeing with. Attached ImagesLast edited by aevald; 07-16-2012 at 07:59 PM.aevald
Reply:Hi all, I had a similar job some time back, had to join a drill bit to a longer shank to make an extension drill....it had to run true.I have two cast iron vee blocks that I use for all welding situations working with round stock.The secret is not to lay the blocks down on the welding table as you normally would but to clamp them against an angle plate.Now the vees are in line when clamped sideways on but not in line looking along the bottom.....you don't want them in line on the bottom, they have to be at different heights to one another to allow for the different diams.So I clamped the one Vee block tightly against the angle plate and down on a 1" thick packer, then  I  clamped the second vee block to the angle plate with another 1" block beneath it....this will allow you to butt weld bars of the same diam in line in two planes.For material with different diams, just put a packer of half the thickness of the biggest rod beneath one of the vee blocks.....the two rods will be in line in two planes.If this was a job that was a regular occurance, I would have the vee blocks with a hole through the side so that they could be bolted to the angle plate and just move one block up or down for half the diam difference.The vee blocks can be made from angle iron welded to a base block....quicker to make than describe.This job can also be done in the lathe....hold one piece in the chuck and the shorter piece in the tailstock with a hollow adaptor or a drill chuck......then cover the bed and Tig weld two good tacks to hold the rods and finally remove and weld fully on the bench.Ian.
Reply:Originally Posted by aevaldhello cromwell, i have included an image which would utilize a length of angle iron and some shims. If you were using 1/2"round and centering it on 1" you would need for the shims to be 1/4" thick, if you were using 3/4" round and centering it on 1" you would need to use 1/8" thick shims. I believe you get the idea. The view that is shown in the image would be looking down from the top. Good luck and best regards, allanedit:have an additional image to give some orientation and also possibly show some access holes to help with tacking while the rods are being held. The shims, as they appear, would be on the inside of the angel and not as they look in the image.
Reply:I use the angle iron method with shims under the small bar.  Use a caliper to check size, then tack.  Roll bar on surface to check alignment, persuade w BFH, tack again and weld.  Works for me.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:i got one for you. take the threaded rod and spin two nuts on the very end of the rod.jamb the nuts tighttake the threaded rod with the nuts on the end to the belt sander.chuck the rod up in a drill and run the nuts across the belt sander with the drill spinning the rod. this will "turn down the nuts"when the nuts are roughly the same size as the outside as the  3/4" pipe use it as a bushing and weld the entire thing to the pipe,  nut, threaded rod an all. As long as the nut and pipe are the same size,  and are flush,  you will be very close to center. Red Neck machine shop!
Reply:Originally Posted by Drf255I use the angle iron method with shims under the small bar.  Use a caliper to check size, then tack.  Roll bar on surface to check alignment, persuade w BFH, tack again and weld.  Works for me.
Reply:Originally Posted by cromwellI have several projects which require me to attach 1/2" rod to 3/4 and 1" rod.  Does anyone have any secrets to centering these to one another prior to welding?I was thinking of two pieces of angle supporting each piece but then I need to shim the smaller so it is centered.  So far I havent not had success with any of my ideas.  Has anyone done this before?  My head hurts .
Reply:Thanks to all for the great ideas!  I ended up trying  aevald's idea of a couple pieces of long angle.  The 1/2" rod was supported the for about 1 foot with shims.  I did a light tack and then spun it to check if it was centered.   I am surprised how accurate  and straight it turned out.  I like jdbuckshot idea of the 'nut' solution also...will have to try that.Definitely need a Bridgeport mill  for production work. Still saving for that.Excellent feedback ...
Reply:You could use extruded aluminum angle since it has sharp 90 degree corners and will nest, unlike steel angle iron. Shim the smaller side with another angle/other shims and you're good.Welding/Fab Pics: www.UtahWeld.com
Reply:Aevald:I agree with your solution.I have a piece of 2 inch angle mounted on the edge of my welding bench for just such a jig. I simply lay in shims and tack them as needed. Works like a dream.Cheers.Glenn.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Get a nice, square cut on the larger rod, debur, then use a small, adjustable square to scribe a small square onto the surface of the fresh cut.  Start with 1/8" protrusion on the ruler, and adjust as necessary, depending on your marking apparatus.  Once you've got the small square's ID sized exactly to the OD of your small rod, you're set.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
GMT+8, 2025-12-27 13:02 , Processed in 0.105237 second(s), 18 queries .
