which one is the best in my pictures
发表于 2021-8-31 23:20:39 | 显示全部楼层 |阅读模式
aforementioned three pictures describe multi-layer or multi-pass weld.i felt that the A and C is better .but the B easy to produce the defect in root .so i hope more experient person tell me the detail .ths
Reply:Personally, I always try to do it this way. Excuse the bad drawing! Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:CEP, looks like you need to turn the heat up!
Reply:Originally Posted by tbone550CEP, looks like you need to turn the heat up!
Reply:Originally Posted by edisonwangbut the B easy to produce the defect in root .
Reply:Bahhhhhhh. Once you smear a lil bondo over it and hit it with primer, it becomes someone elses baby.Ask any trailer company.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I do it like CEP also
Reply:CEP's way is the correct way.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Originally Posted by CEPPersonally, I always try to do it this way. Excuse the bad drawing!
Reply:I have seen procedures that call for it to be done like in pict C, with just 2 passes. But CEP's way is the way it typically gets done..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:One more for the way cep stated
Reply:i hope more people discuss what to happen except defect,for example which one easy to operate ?which one is better to undergo force or loading?
Reply:Is it possible that your native language is not English, and you are using translation software?  We are seeing English words but we are not reading English sentences.
Reply:Originally Posted by edisonwangwhich one is better to undergo force or loading?
Reply:english isnt my native language,but i think language is only used to communicate between people ,if u know my meaning,my english is ok.
Reply:ths, i think the pic A and c is better,
Reply:Wouldn't the passes depend on how thick the material is?Miller 252Miller Bobcat 225Lincoln MigPak 1801959 Hyster forkliftHarris OA torch
Reply:I do it like CEP does it.Yep edison, your engish is very good.
GMT+8, 2025-12-27 13:01 , Processed in 0.093164 second(s), 18 queries .
