Welding Chainsaw Handle - Magnesium?
发表于 2021-8-31 23:20:39 | 显示全部楼层 |阅读模式
Dropped my saw yday and the handle cracked. It's an older model and I believe the handle is magnesium. Haven't done the vinegar test yet. I dont have a Tig unit nor the experience with that process and wondered if there were anyone on here in the HamptonRoads area (757) area code that was close by and could give me  a price on fixing it. It may just be cheaper/easier to go Ebay on the part. I can get a used one for about $25.00. If someone was nearby and $25 is worth it I'd just assume give someone the dough. Probably the filler rod is more expensive that its worth doing?I would try it but have basically no experience with Tig. I just use stick and Mig with argon/CO2. Tks
Reply:If a used part is only $25 then you would be better off to just buy one.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugIf a used part is only $25 then you would be better off to just buy one.
Reply:what saw is it?
Reply:Originally Posted by ironmangqwhat saw is it?
Reply:Thanks all for replies. I'll keep the broken handle in case I ever get a welding process that I can practice with it. Would scratch start Tig on the Lincoln AC/DC 225 be a possible solution to the handle....for practice?
GMT+8, 2025-12-27 13:01 , Processed in 0.103244 second(s), 18 queries .
