20 ton shop press with home made brake
发表于 2021-8-31 23:20:33 | 显示全部楼层 |阅读模式
I recently bought this 20 ton press,at the time I didn't have a use for it but I got a good deal on it.Before I even moved it all the sudden I have a need for it...yes!So after doing some research on press brake's I made one from some scrap that I had on hand.The job that I'm needed some steel plates for connecting the hip rafters to the ridge  and the plate is specked to be bent.Steel was cut with a steel deamon blade and a RidGid wormdrive saw.
Reply:So simple it's outstanding! And just in time for a stormy season?Matt
Reply:That is awesome.  Nice work!Millermatic 135Syncrowave 250
Reply:Nothing like solving a problem with some scrap. It looks like it works perfectly. Good job! Did you run a bead down the center of the angle iron?
Reply:The cylinder blew a seal on my press....anybody know where I can get a kit for it?
Reply:Originally Posted by IamVinceThe cylinder blew a seal on my press....anybody know where I can get a kit for it?
Reply:Thanks bert....I'm making hip plates again and still have a few options.....It most likely is a cheap Chinese cylinder.
Reply:Originally Posted by forhireNothing like solving a problem with some scrap. It looks like it works perfectly. Good job! Did you run a bead down the center of the angle iron?
GMT+8, 2025-12-27 13:01 , Processed in 0.104275 second(s), 18 queries .
