Ruger 10/22 Super Kriss Vector
发表于 2021-8-31 23:20:32 | 显示全部楼层 |阅读模式
decided to make a custom stock for my Ruger 10/22 (.22 caliber long rifle)its a Super KRISS vector im using 16 gauge sheet metal.  i have a Lincoln Weld Pak 100HDthings to do:weld the round tube pieces to the square tubing stock.weld the stock to the upper receiverweld butt plate to stockepoxy glue rubber butt pad to the butt platedraw template for pistol grip/trigger guard area and plasma cut itadd 20" in picatinny rail to the upper receiver for MBUS/eotechadd picatinny rail to the lower receiver for magpulplasma cut and weld the floor of the receiverdrill holes similar to the KRISSweld brackets to the upper and lower receiver for easy disassemblyadd fake selector and safety switchesweld bracket to reuse action screwjb weld 10/22 rotary mag to a extended pistol magcut 10/22 trigger guardcut pvc piping for fake suppressorfill gaps in the lower receiverplasti dip the pistol gripdraw a template for cheek weld on the stock and plasti dipdraw and cut out a kriss logo to the lower receiverclean up the edges and repaint it all blackon008/7619985872/" target="_blank">_MG_3446 by defconskylude, on Flickr_MG_3449 by defconskylude, on Flickr_MG_3455 by defconskylude, on FlickrMy first couple of practice welds with this machine.  Wire speed 1-10 and Voltage A through D.  Using .035 wire.  16 gauge sheet metalI've been using settings 3-C and 3-B and I'm getting these welds that don't look right.  I'll try 3-D and 4D to see if i can get better welds._MG_3459 by defconskylude, on Flickr_MG_3458 by defconskylude, on Flickr_MG_3457 by defconskylude, on Flickr
Reply:here's my other .22 converstion stocks using a Ruger 10/22 and Marlin XT-22 bolt action
Reply:Nice work, the CheyTac is SICK!!!!I would suggest getting the gas solenoid and running the weld-pak as a MIG as apposed to FCAW...You will save yourself alot of time and it will be much easier when it comes to working with that thin stuffMiller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:thanks i get a lot of big smiles from ear to ear when people see this at the rangeill look up how to do a MIG conversion.
Reply:It appears to me that all we're seeing is the back of the welded sheet. on a lot of those. This doesn't give us much to work with for suggestions.But I would say that keeping you practice welds all going in parrallel will help. You'll use far less metal and get a better feel for what your doing. also making sure each weld is done on "shiney" clean metal will help too. Especially with those smaller machines. I'm talking grincer or flappy disk clean, not wire brush clean. Please make sure you're getting good welds with this machine before you start welding on stocks.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:its actually the front.  ive used a gas mig welder before i was getting a lot better looking welds with it.   yea ill clean/grind off the metals next time.yes definitely.  i dont want this falling off.
Reply:Mig is inherently far cleaner than Fluxcore. clean the welds so we can see them. They've got slag similar to stick welding.if those are the tops, than you've got to work on you speed consistancy for sure.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-27 14:51 , Processed in 0.093236 second(s), 18 queries .
