"Hay Rack"
发表于 2021-8-31 23:20:02 | 显示全部楼层 |阅读模式
6061 T6 Fully TIG Welded. 1 1/2 TubeWhat I would consider a lot of weld time. Attached ImagesI hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
Reply:nice... Almost looks like a factory rack.. Btw nice trailer
Reply:nice trailer...Adam MMorales Ranch
Reply:Might want to watch the additional height "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice work.  Oughtta keep the horses happy.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by farmersammMight want to watch the additional height
Reply:For tree branches you might just want to put a wedge on the front out of some tube to help em over the top.   Also helps a bit with aerodynamics if you plate the front with some aluminum sheet.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-27 13:22 , Processed in 0.095065 second(s), 18 queries .
