Custom Air Filter Build
发表于 2021-8-31 23:19:59 | 显示全部楼层 |阅读模式
So, this is the most recent thing that Ive made, and I built it for my shop. Ive got a two year old Campbell-Hausfeld air compressor, that I use a lot, mostly to power my plasma cutter.It used to take these little disposable canister-style air filters, but now, I can't seem to find them anymore.So, I bought a kohler air filer intended for one of their small engines, and I sandwiched it between two pieces of sheet metal, and put it on the compressor.Im really happy with how it came out!! I also painted it with the same truck-bed liner that I used on the fence unroller, and for the curious, I welded it up with my PT225, and I had kind of a gap to fill. The outside of the pipe I used was a little over 3/4", but I only had a 3/4" and a 1" hole saw. So, I used the one inch, and fooled around with PULSE mode to weld up the gap. Anyway, heres the video I made, just wanted to share. Hope y'all enjoy it, it sure was fun to make [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:I like it. Keep up the good work!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thanks, Gamble!! I got to really use the filter today, slicing up some 1/4" plate with the Hypertherm.The compressor fills up faster and "sounds" different/better. Like it was being choked by the clogged up old unit.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Be careful, your old filter probably was a desicant filter (removes water too).  Water will fry your consumables on the plasma torch.You should have used something like this, with water traps or a long line for condensation prior to reaching the filter.  Motorgard filter."Any day above ground is a good day"http://www.farmersamm.com/
Reply:oh crap!!!!!!!!!!!!!!!!!!!  I thought you were making a filter for the plasma, not for the compressor!!!!!!!Carry on.  LOL"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by LanseThanks, Gamble!! I got to really use the filter today, slicing up some 1/4" plate with the Hypertherm.The compressor fills up faster and "sounds" different/better. Like it was being choked by the clogged up old unit.
Reply:LanseLittle trick for you when you plasma cut instead of grinding the dross off just tap it with a hammer around the edge and it pops off.  Hit it parallel with the metal surface Much quickerhave funTom
Reply:Good Vid Lanse.You just reminded me to change my compressor filters!Buy American, or don't whine when you end up on the bread line.
Reply:Great job, been watching your last few projects.  You aren't far from me, i need to come and have you teach me your skills!
Reply:Great job again and thanks for sharing.  Woulda been nice to see you lay down that bead.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Thanks for posting. Like your shop too.You just reminded me that I have to change my air filter and the oil in my compressor.Now.....Why didn't you just cut the 7/8 in hole that you needed with the Hypertherm?Cheers.Last edited by Stampeder; 08-03-2012 at 11:35 AM.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Originally Posted by Mick120Toms right Lanse.....another good idea is, use a half round file as a strop and also as a hammer for the harder stuff.
GMT+8, 2025-12-27 13:23 , Processed in 0.097926 second(s), 18 queries .
