welder
发表于 2021-8-31 23:19:54 | 显示全部楼层 |阅读模式
i want to get a stick welder do build a flatbed,bumper,and weld some hooks on my f350 dually. is there any pertitular things i should look out for when buying off of craigslist?Thanksi will be welding up to 1/2 3/4 rarlyFSAE CAR 1000cc Engine )))lincoln 125+argon conversion kit40cf acly 80 oxy= 97 jeep wrangler lifted 33" tires88 dodge dakota project truck
Reply:If you can't run a couple of rods testing the welder, let someone else take a chance on it.  Trust but Verify.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Originally Posted by nadogailIf you can't run a couple of rods testing the welder, let someone else take a chance on it.  Trust but Verify.
Reply:spend the extra on a ac/dc welder.  you will be much happier with it.MikeMiller Thunderbolt AC/DCMillermatic 211 and spoolmatePower Plasma 50Syncrowave 180 SDMike
GMT+8, 2025-12-27 13:23 , Processed in 0.098700 second(s), 18 queries .
