mig advice
发表于 2021-8-31 23:19:53 | 显示全部楼层 |阅读模式
hey everyone wanted to see if anyone had an oppinion on either a miller 211 auto set or the hobart handler 210. i would like a small mig welder for diong gauged to about 1/4 (multipass is okay) steel and aluminum. both are spool gun compatible. what do you guys think? thanks jaymiller bobcat 250 ntsouth bend metal latheClausing verticle millrikon 17" bandsaweverlast 250exharris oxyfuel set upspeedglass AD helmet with adflo power respirator.
Reply:they are both top notch machines....neither one will let you down......do you need the auto set capabilities?  if not dont spend the money for it.....performance wise they are equal.   maybe let the wallet and best buy  make the decesion.  i was looking at these and a good buy presented it itself on a Hobart Handler 190 and i grabbed it.  one step back from these machines will still give you what you are looking for.do you have 220 in the garage already? if not the MVP 110/220 option lets you buy up and use it now.where in central Jersey?  we moved away from the shore a couple of yrs ago....i miss itLast edited by 37ford4dr; 12-30-2011 at 11:37 AM.bobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:thanks for the info i already have 220 and  exit 74 on the parkwaymiller bobcat 250 ntsouth bend metal latheClausing verticle millrikon 17" bandsaweverlast 250exharris oxyfuel set upspeedglass AD helmet with adflo power respirator.
Reply:got it, we were north at gsp 98.  if you have the 220 you may never need the mvp 110/220 option that is available, i guess my point is the options are what drive up the cost of the welders, that was why when i got a good deal on  the 220v only  HH190   i grabbed it.  there is no reason not to go up and get more bells and whistles if the pockets are deep enough.....i used my left over change and bought a plasma cutter. bobbobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:since Miller and Hobart are the same company, I'd assume the two are the same apart from some bells and whistles on the Miller.
Reply:Originally Posted by Groosince Miller and Hobart are the same company, I'd assume the two are the same apart from some bells and whistles on the Miller.
Reply:Take a look at the new Thermal Arc Fabricator 181i - MIG, stick and Tig at 150 DC amps for $800.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
GMT+8, 2025-12-27 13:22 , Processed in 0.108737 second(s), 18 queries .
