spoolgun or permanant mig
发表于 2021-8-31 23:19:40 | 显示全部楼层 |阅读模式
guys does a spool gun work as good as regular mig welder or what are the pros and cons if a spool gun works good what brand Quality is our policy.
Reply:If you are bent on running 1lb spools, you can still load it in a regular mig, no need for a spoolgun.If you really find then need for alum, a spoolgun is your best bet.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I don't understand what you mean by "permanent mig".  Are you going to try and run a spoolgun off of a stick welder or something?  You need to have a MIG welder first, the spoolgun is an add-on. Originally Posted by SundownIIIDon't get me wrong.  They are just as ill informed about politics as they are about welding, they just post more on that subject.
Reply:Originally Posted by jmtebbensI don't understand what you mean by "permanent mig".  Are you going to try and run a spoolgun off of a stick welder or something?  You need to have a MIG welder first, the spoolgun is an add-on.
GMT+8, 2025-12-27 14:51 , Processed in 0.134795 second(s), 18 queries .
