I Searched/More info on Dual VS Single Flowmeters
发表于 2021-8-31 23:19:38 | 显示全部楼层 |阅读模式
I am looking for a flowmeter for my Dynasty & only want to buy it one time and one that will last/rebuild able if needed..just looking for more info on pro's and con's of Dual & single Flowmeters..thanxs for any help -PaulMiller 211 & Spoolmate 100Miller Diversion 165Miller Spectrum 875
Reply:i use a victor flowmeter (ball float)been good for 20+ yrs  has not let me down forney makes a good one also about 75+buy a name brand for service an repair parts they can range form $49+ to over $ 250idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:a dual flowmeter setup will make it easier to backpurge with a single bottle if your welding things that need backpurging.XMT 350 MPa, w/D52-DTA 185 TSWHarris of
Reply:I have a dual flowmeter. I think it's the Harris 356. Didn't like the plastic knobs on it, though. I had the machinist make a couple of nice knurled brass ones. Other than that it's fine. Another option that I use is a CGA 580 tee with 2 single flowmeters attached. With that set-up you can keep a flowmeter on your TIG rig and one on your MIG gun, and just pair them up when you need to purge.
Reply:Dual meters on a tee works nicely. I set them up that way at the school where I worked. One reg getting damaged doesn't take out both.
Reply:I have a dual flow regulator for my TIG. I use it for stainless all the time.  It uses a lot of gas however so charge appropriately.I also use it on aluminum fuel tanks for the race cars and streetrods..  It makes a better weld on the inside.  Again it can use a huge amount of gas.  I paid about $180 12 years ago from Tig Depot.I think it is well worth it.
Reply:The CGA-580 tee:Search for "Western T-92CV Tee CGA580 M/F/F" for current prices.
Reply:You can get the Smith dual flow meter for about $170.  Its a bit bigger/bulkier than the Victor one but the Victor one is about $250.Of the easy to find flow meters, Smith seems to be the most expensive and presumably the best.  I know that every LWS in the area will rebuild them no problem.  It will last you forever.However, Miller now comes with Smith regulators and so far they have worked flawlessly and they are a bit cheaper.  My old Millers have Victor, my new ones are all Smith.http://store.cyberweld.com/smduflre3...6c726533307365Last edited by con_fuse9; 11-14-2011 at 12:28 PM.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:When is back purging needed?When picking a meter, What info do you need, Gas's tank inlet size?I see so many on eBay from weld fabulous..Miller 211 & Spoolmate 100Miller Diversion 165Miller Spectrum 875
Reply:Originally Posted by CorbinworksWhen is back purging needed?When picking a meter, What info do you need, Gas's tank inlet size?I see so many on eBay from weld fabulous..
Reply:Not sure what welding fittings pure CO2 uses.
Reply:Originally Posted by con_fuse9You can get the Smith dual flow meter for about $170.  Its a bit bigger/bulkier than the Victor one but the Victor one is about $250.Of the easy to find flow meters, Smith seems to be the most expensive and presumably the best.  I know that every LWS in the area will rebuild them no problem.  It will last you forever.However, Miller now comes with Smith regulators and so far they have worked flawlessly and they are a bit cheaper.  My old Millers have Victor, my new ones are all Smith.http://store.cyberweld.com/smduflre3...6c726533307365
Reply:Originally Posted by deriliousI have that same regulator, bought it from Cyberweld too! It's got 3 scales so I sometimes find myself staring at it a little too long trying to figure out which scale is for argon. That's my only little annoyance with it. Oh and running the other flowmeter for purge puts a hurting on my little 125CF tank.
GMT+8, 2025-12-27 16:30 , Processed in 0.170877 second(s), 18 queries .
