Intermittet butt weld strength calculation
发表于 2021-8-31 23:19:35 | 显示全部楼层 |阅读模式
we have a circular intermittent butt weld design. Each weld is 1 inch and totally four welds distributed evenly (90 degree apart) on the joint of two pipes the OD of which are 5.4 inch. Two pipes are welded by using stick welding (SMAW).Please provide your expertise on the questions:1. How to calculate the weld strength of such intermittent weld if a torsion T lb-ft is applied on the intermittent welds?2. Is the weld strength linearly propotional to the amount of the welds?Last edited by raykee; 01-08-2012 at 09:30 AM.
GMT+8, 2025-12-27 14:51 , Processed in 0.095315 second(s), 18 queries .
