查看: 13|回复: 0
6g tig root/7018 fill #pics
发表于 2021-8-31 23:19:33 | 显示全部楼层 |阅读模式
In welding school at the moment...Here are some pics of my 6g! I'm looking for some tips and advice in this position! I am free handing the root but I would like to know how you pipe guys put it in? Free hand/ walk the cup or do you free hand the bottom and walk the rest?Anyways all tips and advice welcomed!Here are some pics! ThanksSent from my iPhone using Tapatalk
Reply:Sent from my iPhone using Tapatalk
Reply:And I capped it with 3/32 7018Sent from my iPhone using Tapatalk
Reply:Looks very good!
Reply:Agree they look pretty good.  See some heavy penetration, imagine on high side.  Try keeping your filler a little higher out of the gap and working your arc higher up each bevel.  Second pass on your cap could be a little larger.  Have you tried using 4 passes.  On the first three, tighten up so each pass overlaps at least to the center of the preceding and then a quick stringer.
GMT+8, 2025-12-27 16:30 , Processed in 0.133166 second(s), 18 queries .
