Harris safety silv-56 FC
发表于 2021-8-31 23:19:32 | 显示全部楼层 |阅读模式
Anyone ever use the stuff ?It's about all I can put mu hands on for a lil stainless work here without buying yet another bottle of gas....although I'm not sure I buy into the need for helium when welding SS with a mig.Nah. Too thin to stick it. .045. I prolly could but it's a repair and i don't have any scrap ss that thickness to try and destroy.I figger I'll lay some sliver in it and buff it up.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Hey Burp, what's the application?  I've used Safety-Silv before with good results, but don't remember the #Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by dubl_tHey Burp, what's the application?  I've used Safety-Silv before with good results, but don't remember the #
Reply:yea it was flux covered, seems like it was 45, or whatever was recommended for joining dissimilar metals.So basically you just gotta weld a tear?If I remember correctly, the # corresponds to the heat range, although there's some more to the metallurgy.  I know the guy at Airgas was pretty knowledgeable.Last edited by dubl_t; 02-22-2014 at 01:50 PM.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by dubl_tyea it was flux covered, seems like it was 45, or whatever was recommended for joining dissimilar metals.So basically you just gotta weld a tear?If I remember correctly, the # corresponds to the heat range, although there's some more to the metallurgy.  I know the guy at Airgas was pretty knowledgeable.
Reply:well whatever you do, post pics please ...no silly, not of the solder and repair, some more of your beach bunnies Seriously, looks like 56 is what you'd want: http://www.harrisproductsgroup.com/e...Silv-56FC.aspxLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
GMT+8, 2025-12-27 14:51 , Processed in 0.102376 second(s), 18 queries .
