But How Does He Unbolt the Channel?
发表于 2021-8-31 23:19:26 | 显示全部楼层 |阅读模式
http://www.practicalmachinist.com/vb...you-do-179769/I'm looking to do something similar (channel instead of plate top), but I can't figure out how he can 1. unbolt it2. get the nut out once it's unbolted from the I beamAnybody have any ideas on how else to put the channel on there, short of welding it on?
Reply:Originally Posted by RhymesWithBobhttp://www.practicalmachinist.com/vb...you-do-179769/I'm looking to do something similar (channel instead of plate top), but I can't figure out how he can 1. unbolt it2. get the nut out once it's unbolted from the I beamAnybody have any ideas on how else to put the channel on there, short of welding it on?
Reply:So... just consider the 6 nuts (per channel) collateral damage of replacing the channel?
Reply:Originally Posted by RhymesWithBobSo... just consider the 6 nuts (per channel) collateral damage of replacing the channel?
Reply:Ditto whats been said. Nuts and bolts are cheap AND, you can get it apart to fix it. If you don't like the design just bore a hole in one side to be able to get a wrench in there.
Reply:Originally Posted by RhymesWithBobI'm looking to do something similar (channel instead of plate top), but I can't figure out how he can 1. unbolt it2. get the nut out once it's unbolted from the I beam
Reply:if you're going to be cutting/grinding stuff off to take it appart anyway why not grind out the welds? that way you're not having to cut, and drill another section of channel to weld to. you're just putting the new section of channel on and welding it on.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:If you think you will have to replace these channels that frequently you need to consider using heavier material or a different design.
Reply:I was thinking of using some scrap 12" c-channel to do a similar table.  A neighbor gave me about 50 feet of it."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Do you (all) think that welding the channel to the top face of the I beam would produce a great table to make canoes on since it would warp upwards like a banana with the heat?  Or, would that chuck of I beam resist the force?It really does look like a handy fab table that could be built for less than the cost of a 1/2" or better plate surface.  Does a guy really have to drill all those holes to keep it flat?Miller Syncrowave 180SDLincoln WeldPak 100 with gasHandheld Milwaukee BandsawO/A Cutting Torch
Reply:A friend that has a welding business in another city, needed another table for a big rail job he got so he built one like this. He came to my shop to use my table to build his on as my top is 1" and very straight. We built the table upside down on my table. We sat all the channel on the table with 1" spacers, set 12"x19# I beams on top of the channel and tack welded the channel to the I beams. Then we welded 3 1/2" pipe to the I beams for legs. We picked it up with my lift and turned it over and he welded the channel to the I beam.  It came very straight and he has been using it for about 2 years now with no problems.
Reply:Very cool idea.IW Local 580 NY, NY
Reply:Thanks BobI'd have to scale down from a 12" I beam quite a bit.   Also since I don't have an existing good table (that 1" one sounds fantastic) or a good way to roll a steel table over in my garage I'd have to build it right side up.However, the heat from your friend's welds on the top flange didn't hurt the table so I might go that route.Miller Syncrowave 180SDLincoln WeldPak 100 with gasHandheld Milwaukee BandsawO/A Cutting Torch
GMT+8, 2025-12-27 16:30 , Processed in 0.097131 second(s), 18 queries .
