Low Overhead Discount Welding
发表于 2021-8-31 23:19:25 | 显示全部楼层 |阅读模式
Today I was "that guy" did a small trade job for a buddy of mine out of the trunk of the car. Diesel is expensive and I only needed a few things. An ex renter backed the Uhaul in to the railing and it needed a fix. Attached ImagesLast edited by TozziWelding; 08-15-2012 at 07:05 PM.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I did the whole job with my Maxstar 150STH, portaband, 4.5" grinder, level and a tape.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Nice!  But... you didn't put the adjustable joint back on?  You spoiled the "period" railing and reduced the value of that antique home??!!   tsk tsk.Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Don't forget the radio Bruce
Reply:Looks like money in the pocket!  Good dealMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:Adjustable joint was smashed from said Uhaul truck.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:And now you have photographic evidence that the family car is used for business purposes and those expenses are now deductible as wellBonusWhen any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you must not see, this you are forbidden to know," the end result is tyranny and oppression, no matter how holy the motives.
Reply:What is that old shield you have there, It looks like one I used to have, made by Union Carbide, boy did I get a lot of miles out of mine.    it's claim to fame when I bought it was it was unbreakable, and it was."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Kolot, that is a Fibre-Metal pipeliner hood, I just chopped the neck down. It is unbreakable and always works unlike a 300 dollar autodarkener.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by SRO1911And now you have photographic evidence that the family car is used for business purposes and those expenses are now deductible as wellBonus
Reply:Did you put up anything to protect passers-by from the arc flash?I want to weld outside, but am always worried about messing up someone as they walked by.
Reply:Looks like a job I did last year, Maxstar 140, a hood and some rod, a little grinding, Done all out of the backseat. Its amazing what these little welders can do for ya, Ive dragged mine through crawl spaces and duct chases, even spent a good bit of time in the walls of a school behind the lockers (not a fun place to be when the light goes out, its basically a 2x200' darker than hell hall with sharp stuff sticking out all over the place and no easy way to thread yourself out without a light.
Reply:Originally Posted by RhymesWithBobDid you put up anything to protect passers-by from the arc flash?I want to weld outside, but am always worried about messing up someone as they walked by.
Reply:Osha guidelines for arc flash protection are 25'Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Nice job. Also how do you like your maxstar 150sth?  I'm thinking of possible buying one? Any likes or dislikes about the machine? Also like the welding hood nothing better than a pipelinerMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:Nice job, I love those little maxstar welders, I want one sooo bad, my old boss had two. http://www.philswelding.com
GMT+8, 2025-12-27 15:00 , Processed in 0.082361 second(s), 18 queries .
