查看: 13|回复: 0
Welding rod sticker shock
发表于 2021-8-31 23:19:20 | 显示全部楼层 |阅读模式
I ordered some fancy welding rod that will weld tool steel and spring steel. I only ordered two pounds just to try it out. It's a good thing I didn't order more because it ended up being $150 for two pounds of 3/32. I didn't think to ask the price first because I had no idea that welding rod could cost this much. It's Brutus - A  rod from Rockmount. 125,000 PSI with 30% elongation before failure. The weld bead has a gold color ....I guess there is gold in it at that price.
Reply:thats a nickel rod.Nickel rods are always VERY expensive. Nickel aint cheap, and we dont grow it here- its all imported.But sometimes, its the ticket.I like to tig weld broken cast iron with nickel rod- no preheat or postheat, and it really works.But you gotta pay to play.
Reply:A cheap alternative are E312 electrodes, commonly sold as "weldall". Note the properties of tool steel or spring steel will dramatically change adajcent to the weld deposit.Cheers
Reply:I know this is an old post but if anyone is interested I have a 10lb box of the Brutus-A Rockport rod in 1/8 in available for $200 plus shipping.  I got this as part of a package purchase with a welder and I just don't need it.  It is a full box.ThanksGreg360-320-3436ab7r at cablespeed dot comOak Harbor, WA
GMT+8, 2025-12-27 15:09 , Processed in 0.128046 second(s), 18 queries .
