Miller Syncrowave 250 Argon To Tig Torch Connection
发表于 2021-8-31 23:19:18 | 显示全部楼层 |阅读模式
I have an older Miller Syncrowave 250 I purchased used and would like to use a CK single superflex power cable 17 torch.  I am wondering what would be the most efficient way to hook this up.  I have a power block adapter that bolts to the lug on the welder.  I have a Smith regulator supplying the supply side of the gas solenoid.  Can I just run a pigtail hose from the solenoid to the supply side of the powerblock, then hook the torch up to the powerblock?  This seems pretty basic to me and the Radnor catalog I got from Airgas shows this basic hook up in their diagram.  I would appreciate any advise anyone has to offer.  This would be an air cooled torch by the way...Thanks,EricMiller Syncrowave 250Miller ThunderboltMiller 211Hypertherm Powermax 30
Reply:I did as you said.  Same welder.
Reply:Thank you, just what I needed to verify.  I appreciate it Originally Posted by brendonvI did as you said.  Same welder.
GMT+8, 2025-12-27 16:32 , Processed in 0.122890 second(s), 18 queries .
