Almost ready..
发表于 2021-8-31 23:19:17 | 显示全部楼层 |阅读模式
Pick up my new Miller 211 this past Saturday and have a electrician friend comming today to wire up the 240 in my garage.  Can't wait to start welding with this machine.  I have used other 211's in the past and really liked them so when it was time to upgrade I went with it.  I have not tried it on 120 yet because the project I am doing will need the power of 230.  Now if the weather would warm up here in WI that would help a lot!
Reply:Congrats! You will enjoy that welder.Post some project pictures when you get started.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:''Now if the weather would warm up here in WI that would help a lot '' ! I agree, I'm not too far south of you at the WI/Il line and it sucks !  Dam near -3 this AM and cold all week with some or a lot of that white stuff coming !  Yep, the 211 is a super machine. I have a 3 point back blade to repair , got it ready to weld but dam cold. I might have to get some kerosene for the torpedo heater to have some heat to get it welded.
Reply:I hear you BD1.  I have a propane contractor heater for my garage but when its this cold it does not do much.  At least my friend got a temporary 240 line to my garage.  Will put a permanent line in when we can dig the ground up to bury the line.  Hope this cold snap ends soon.  I have some wire to burn.
GMT+8, 2025-12-27 15:00 , Processed in 0.075697 second(s), 18 queries .
