new wire
发表于 2021-8-31 23:19:14 | 显示全部楼层 |阅读模式
OK. Here are 3 pics of my average weld bead today. This is on .118 hot rolled scrap mild steel sheet metal w/o mill scale removed using the ProStar .030 I posted the question on a few days back. I used 75/25 gas @ a 20 flow rate with a "c" power setting, obviously on my Lincoln 180HD tapped machine and a wire speed of 3. I'm trying to keep the bead width appropriate to the metal thickness as suggested before and I think my beads are getting better but I have nothing but your comments to judge by. So, what do you think?
Reply:Your pics didn't post1982 miller blue star 2E ac/dcHarbor freight flux core posVictor oa
Reply:Oops. Sorry. Knew I forgot something!!!!:
Reply:Looks pretty good. Little more hand/speed/motion/puddle(all bout the same) control then it becomes muscle memory. Already surpasses 90% of the farm welds I've seen. Carry on, Sir.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Looks like you need to hold the edges a little longer.Farmer?Hobart Champion EliteMiller S-32p 12Lincoln sp175tLincoln 225 ac tombstoneHarris oxy/aceteleneMakita grinders/chopsawHypertherm Powermax 45
Reply:Can you tell me why? What should they look like so I'll know. And thanks.
Reply:Mostly for uniformity, because it appears like there are spot where you are briefly hitting the dge and others where your holding it longer.  I also think the edges look a little cold where your not holding it long enough.   The welds are good, I just sense based on your other projects that you are looking for "great".Farmer2Hobart Champion EliteMiller S-32p 12Lincoln sp175tLincoln 225 ac tombstoneHarris oxy/aceteleneMakita grinders/chopsawHypertherm Powermax 45
Reply:I am but then again I'm just that way. Been driving the wife crazy for 21 years now but I've never tired of the feel of anything done to perfection. I look at the welds that Paul does and alot of the people on the Mig like Tig thread execute and keep thinking, "Why can't I do that." I figure with adjustments here and there, little by little I can. I'll get this welding thing figured out yet.  Thanks again for all the help.Last edited by jlames; 02-27-2014 at 12:33 AM.
Reply:Looks pretty damn good to me. Probably better than 98% of the welds I have seen from SO called welders I have worked with on drill rigs and people around here who make repairs/builds of there own. When I say around here I dont mean the forum I mean in my local. Wanted to clear that up before I get cyber-raped...HH140---------------------------https://www.facebook.com/brandon.pike.9
Reply:Thank you Brandoman. Means I'm on the right track.
GMT+8, 2025-12-27 15:00 , Processed in 0.072322 second(s), 18 queries .
