查看: 2|回复: 0
Just A Small Atleration Please...
发表于 2021-8-31 23:19:10 | 显示全部楼层 |阅读模式
My parts man is big into guns..Brought me a piece where the strap goes but wanted it moved to the side rather on the bottom...So armed with a piece of 1/4" round 316 stainless and a tiny lathe I had to make a new receiver for the clip where the strap goes but it could not be drilled all the way thru because then the clip would not stay in the middle..Then just fill in the original holes where the clip was..(Last pic)...Pics tell the story..150? amps...045 309 filler3/32"Red SHARP tungsten..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hummm, I would have drilled all the way through the middle, and just used a stainless roll pin in the center, but that sure works just as well too.
Reply:Nice As Always ZAP.. Looks to be a Barrel Band from a Ruger Mini-14?Red.......Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:That what it looks like to me too and i just buy the sling adapter that fit a i think it was a winchester 94 had a band that clamped onto the barrel and swiveled works good without modifying the original partoop's to late nowBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:You do get the challenging ones... Nice job.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Man I thought that guns were illegal in Mass.  Maybe moving back there is an option
Reply:Barrel-band sling mount attachment - check.Change under-mount sling point into side-mount sling point - check.Stainless is fine and all, but if the owner ever wants to 'dull' that metal or blue it (actual hot blue in a chemical tank or just some 'cold blue' touch-up stuff), then the stainless is going to stand out like a bright shiny sore-thumb. Just an FYI.  Unless the original piece(s) were stainless, in which case your change matches the rest of the metal.Oh, and although it's not going anywhere, I think it would have looked 'nicer' if you had run the weld bead all the way up to the top of your stainless nubbin.  Looks like you stopped about 3 dips short there.  Nice fill-in on where the original holes were.  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by MoonRiseBarrel-band sling mount attachment - check.Change under-mount sling point into side-mount sling point - check.Stainless is fine and all, but if the owner ever wants to 'dull' that metal or blue it (actual hot blue in a chemical tank or just some 'cold blue' touch-up stuff), then the stainless is going to stand out like a bright shiny sore-thumb. Just an FYI.  Unless the original piece(s) were stainless, in which case your change matches the rest of the metal.Oh, and although it's not going anywhere, I think it would have looked 'nicer' if you had run the weld bead all the way up to the top of your stainless nubbin.  Looks like you stopped about 3 dips short there.  Nice fill-in on where the original holes were.
Reply:Big red gets the gold star. While not 100% technically correct. he was the first to correctly identify the rifle. The part is actually the gas block (the mini does not have a barrel band unlike it's little brother the 10-22)The gas block redirects the gas pressure from the barrel through the gas bushing and out the gas pipe to the op-rod. (Zap also made me a reduced size gas bushing to go in it)The whole idea was to produce an AC556 clone. The AC556 is the full auto version of the mini14. They had the sling swivel on the side.Here's a pic after I hit it with 80 grit alum oxide  and re-installed on barrel and the gas pipe attached. Attached ImagesLast edited by 7.62x39; 08-17-2012 at 11:39 PM.
Reply:Fully assembled
Reply:7.62 no picts showing.....No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Sorry how about now? Attached Images
Reply:Eaton folding stock good choiceBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by MoonRiseStainless is fine and all, but if the owner ever wants to 'dull' that metal or blue it (actual hot blue in a chemical tank or just some 'cold blue' touch-up stuff), then the stainless is going to stand out like a bright shiny sore-thumb. Just an FYI.  Unless the original piece(s) were stainless, in which case your change matches the rest of the metal..
Reply:This is the look we were going for.Factory Ruger AC556 folder gas block. Attached Images
Reply:I tried registering at your site yesterday afternoon but never got the "code" via e-mail yet?I am at the shop now but will try again this afternoon when I get back home..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I chose the Eaton stock for mine because when extended the gun balances perfectly in one hand Most stocks for military weapons have sling on the side unless you want the magazine digging you in the backAnd i went with a sling adapter for the winchester 94 30-30 because it clamped just forward of the gas block and could be mounted in any direction with out having to modify the gas block at allThe 3 rifles that i shot competitions with were the mini 14 the AK 47 and my FN-FALall were accurized and modified by meBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Nice work!!
Reply:killdozer.I'm primarily an AK guy myself. Built many variations. Check out one of my builds here. It's a Yugo M-92.http://www.gunco.net/forums/f43/krink-de-mil-22463/http://www.gunco.net/forums/f50/krink-build-28744/
Reply:I could not see the pages without registering  and i'm needing to get going today We need to B S about guns sometime without derailing someone else's threadBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:View as a visitor only. http://www.gunco.net/forums/"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Cliff's notes version.Start with this.add this.end up with this.
Reply:dang. 7.62 s post are being censored and blocked.  almost like big bro watches what the little people say and makes it hard for them to share ideas. hmm.
Reply:Originally Posted by lincwelddang. 7.62 s post are being censored and blocked.  almost like big bro watches what the little people say and makes it hard for them to share ideas. hmm.
Reply:it looks like someone is blocking his posts about guns. no zap, no finger is being pointed at you.His photos didn't load right or were the wrong size I always re size to 600 X 800 pixel so they load but other things can go wrongBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by lincweldit looks like someone is blocking his posts about guns. no zap, no finger is being pointed at you.
GMT+8, 2025-12-27 15:00 , Processed in 0.244030 second(s), 18 queries .
