new lincoln 256 mig
发表于 2021-8-31 23:19:02 | 显示全部楼层 |阅读模式
anyone been on linc website and see the 256? just wondering what the thoughts on that were
Reply:Looks like a nice machine, amp range of 30-300 amps. seems to be the same as the 255xt at $800 lessTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I was checking it out yesterday, looks pretty good. I wonder what they'll retail for if msrp is only $2k, if it's around $1600 like the MM212 or Ironman 230 I can see Lincoln getting some extra sales.Millermatic 211 Lincoln Idealarc 250-250, ~500lb water cooled tig
Reply:I had emailed customer service and asked about what is different from the 255 machines. Their response was:"The PM256 was an upgrade from the PM255XT,just a different control board layout,same capabilities.The PM256 will do 3/8 aluminum single pass,1/4" multiple pass, staying in the duty cycle.As to the short circuit or spray, that has to do withyour weld procedure, type and thickness of material.The 250LX Spool Gun will hook right up to the unit.This machine is rated 250 amps at 40% duty cycle and300 amps at about 20% duty cycle.The input needed for this machine is 230 volts 60 amp service".K3069-1 One-Pak® Includes:
GMT+8, 2025-12-27 15:20 , Processed in 0.103605 second(s), 18 queries .
