Some boat projects I have been working on.Sent from my ADR6350 using Tapatalk 2 Attached Images
Reply:Sent from my ADR6350 using Tapatalk 2 Attached Images
Reply:I can tell by the rails and lights on front of the boat it is for bow fishing. But the structure on the back, is that to mount something like an airboat engine type set up on it? That's the only thing I can come up with for that piece, so you can get in to shallower areas than the outboard will take you.
Reply:The first 2 pics of the flounder boat it is just tacked up with spoolgun then the last pics of it is after it was TIG finished.
Reply:It is for flounder gigging there will be a 10hp Kohler motor mounted on the back with a prop to push the boat in shallow water and a alternator to run the lights witch are 12 volts.
Reply:Originally Posted by fowlwatersIt is for flounder gigging there will be a 10hp Kohler motor mounted on the back with a prop to push the boat in shallow water and a alternator to run the lights witch are 12 volts.
Reply:Where can I find 12 volt lights like that?
Reply:Nice looking rigs. Did you also weld up the pods on the back of the aluminum boat?
Reply:Originally Posted by jess722Where can I find 12 volt lights like that?
Reply:I can get the lights if you want to buy them however they are not cheap. PM me if you would like to buy. The 4' floresent light is all alumunim houseing 12 volt $300
Reply:What pipe bender are you using?
Reply:JD2 model 32
Reply:Originally Posted by fowlwatersJD2 model 32
Reply:It is mill finished aluminum pipe.
Reply:nice photo guys, thanks for allrumah dijualweb directorymobil dijualdirektori perusahaan
Reply:Mick120 not flatening in the bends the front of the flounder boat it 1" sch.40 the back of the boat is 1.25" sch.40.
Reply:Nice work looks good. http://www.philswelding.com |
