Question cwi d1.1 questions
发表于 2021-8-31 23:18:45 | 显示全部楼层 |阅读模式
Going to retake part c on the cwi test I'm looking for advice.  Any help would be great.  Study suggestions?  Did 2 weeks at Hobart it was a very good class but failed the code. I just don't know what to study.
Reply:Give yourself a ton of time before you go back.  Keep doing practice tests that you got.  You should be able to move around the book like a ninja.  Get as familiar as you can with where things are.  You need to immediately know what clause the answer will be found in.  Like prequalified almost always comes from clause 3.  Don't get tricked.  Some of the questions will lead you in the wrong direction.  Read the entire code book.
Reply:I took the test with api 1104. I put tabs on the sections for quick findsSent from my SGH-M919 using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Thanks guys.  I'm thinking of buying the $57.00 study guide from AWS. Anyone use this?
GMT+8, 2025-12-27 15:21 , Processed in 0.078265 second(s), 18 queries .
