Funky chunky blue 300
发表于 2021-8-31 23:18:42 | 显示全部楼层 |阅读模式
This is a new one on me? Four big pull switches on the bottom left instead of three?Everything works but control of the heat...It runs wide open! Any suggestions... and i will forever be your slave!Thanks in advance!!    -Sean
Reply:Pimp: give us some more information. Are you using a foot pedal or a thumb switch? Is this a shared machine or a you the only one using it?
Reply:Unit SN?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Gotta weld really really really fast....... had to say it.  Sorry man hope you get it figured out those are good machines.
Reply:The unit came out of Pratt & Whitney... they rebadge them so there is no serial # only there #Got more pics
Reply:More
Reply:More
Reply:Foot Petal... Pics AboveLast edited by SPL_PIMP; 03-06-2014 at 12:17 PM.
Reply:I can speed weld...but i dont know all about that!!!lol
Reply:RFCS-14 with a Profax adapter
Reply:So you purchased the machine with this issue? Or was it working fine then developed this issue?Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Originally Posted by That Guy ThereSo you purchased the machine with this issue? Or was it working fine then developed this issue?
Reply:Schematic on the panel is # C-084602-A if that helps anyone.. Thanks very much That Guy There!
Reply:Have you verified the problem? if so have you tried to isolate it? disconnect the foot pedal to rule it out? try stick welding and adjust ampsMillermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Originally Posted by That Guy ThereHave you verified the problem? if so have you tried to isolate it? disconnect the foot pedal to rule it out? try stick welding and adjust amps
Reply:From what i have read about problems it needs a resistance on the torch to understand how much power u are set too. LEM a heavy wire that runs through a coil...like an amp probe sends a signal to the PC 1 to calculate were the setting is at.
Reply:Hall effect...no power= wide open!! hmmm but why....more wire chasing
GMT+8, 2025-12-27 15:21 , Processed in 0.116907 second(s), 18 queries .
