Lathe back splash add on
发表于 2021-8-31 23:18:36 | 显示全部楼层 |阅读模式
Finally got 'round to it.  I'm tired of oil up the wall and piles of shavings behind the lathe.  So I'm adding on the the back splash.  First pics are in the original intended position.  The top is horizontal, but seems like it might be too low.  Second pair is in a higher position and the front edge is about forehead height.  Last pic is the addition laying down.  I had planned to just weld the addition on the the top of the old back splash, but seeing it laying down got me thinking.  If I was to mount it with a piano hinge then I could fold it down as a dust cover.  I might have to get creative with the end caps (yet to be made), but it is a possibility.  I intend to add a light behind the front edge so I can better see what I'm doing.  I thought an led strip would be nice.Yes I know I left the chuck key in.  It is in there to show clearance for the pics.Any thoughts? Attached ImagesMy name's not Jim....
Reply:I see more pluses than negatives. In fact I'm not easily able to find a negative. If you're happy with heights and distances relative to your forehead, when machining, then I'd say go ahead with it. Make me one while you're on! Oh, hang on a minute, distance might be a problem.In it's flat position, the only possible flaw I'd see is that it's a flat surface I'd be tempted to "put something on just for a wee while", then when I wanted to use the lathe, I'd have to find another parking spot.I don't think you'd want it to stick any further out when it's flat as I know I'm a bit crowded by the lathe and it would be a nuisance if anything could get caught on it as anyone moved by it.Great idea, might make one myself!"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:i would want it as high as you could get it, like the second to last picture or maybe even a little taller... Would be nice with some recessed lights and protective grills on the top .. or maybe a small recessed and covered flourescent light..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Very nice!  How are you liking your lathe and mill?
Reply:I know it's only temporarily supported in the "up" position, but you really don't want it leaning over the work area.  When you get the hinges on, make sure it can be put into the full vertical position & will stay there without having to use a prop rod.  Maybe a gas strut from a mini-van lift gate?I like the idea, mine isn't quite so tall & doesn't fold.  But I sure like having the backsplash better than without one. Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I like the addition of the splash guard. How are you going to keep in the upright position? Chain from wall? Prop rod? I read where you left the chuck key in for clearance testing, I had an instructor that would crawl your *** for leaving it in the chuck. Your hand never came off of it from the time you picked it up until you laid it back down. Only got the receiving end of one of those *** chewings to learn that lesson.Last edited by bhardy501; 08-19-2012 at 09:43 AM.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Reply:Nice looking jet lathe, oh the work I could do with one that size( maybe some day)Most lathes have the chip guard / back splash set upright if you don't run a lot of coolant over long bar type work, if using a lot of coolant where it gets spun off most times only a full cover will keep it inside the machine.If you are doing most of your work close to the chuck have you looked at the clear lexan shield lathe guards?I have ran lathes with them and they do help to keep the chips and coolant where they should be inside the machine.If I were to have the back splash laying  down over the bed (your last photo )to be a dust cover, I would add some canvas along the top to fold over to close up the front. When going to use the lathe fold the canvas back over the back splash before setting it upright and locking it in place.But some times the things I thank will be jest the it's don't work so well.
Reply:Take that key out of the chuck Not Jim!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by brucer ...or maybe a small recessed and covered flourescent light..
Reply:Originally Posted by MarkBall2I know it's only temporarily supported in the "up" position, but you really don't want it leaning over the work area.  When you get the hinges on, make sure it can be put into the full vertical position & will stay there without having to use a prop rod.  Maybe a gas strut from a mini-van lift gate?I like the idea, mine isn't quite so tall & doesn't fold.  But I sure like having the backsplash better than without one.
Reply:Originally Posted by TractapacIn it's flat position, the only possible flaw I'd see is that it's a flat surface I'd be tempted to "put something on just for a wee while", then when I wanted to use the lathe, I'd have to find another parking spot.
Reply:I decided to forget the hinges and just weld it on.  It ended up a little higher than previous pics show.  Even standing on my tip toes and leaning in, the front edge just barely touches my hair so I won't be banging my head on this thing.  The front edge is also about 4" behind the spindle center line so hoist use in the future for loading won't be a problem.I need to do a bit more welding, then some prep work and paint.Last pic shows the head stock back splash intended position.  It's about 12" tall by 18" wide.  A lip will be added to it also.What kind of paint will hold up to brake cleaner? Attached ImagesMy name's not Jim....
Reply:Originally Posted by Fabn4FunUs woodworking hobbyists had a problem with fluorescent lights close to the lathe work area.  The 60hz flicker would make the spinning workpiece look like it was writhing or undulating and hard to focus where I was hand feeding the chisel into the work.  But that splash / cover will really help!
Reply:Originally Posted by BoostinjdmI decided to forget the hinges and just weld it on.  It ended up a little higher than previous pics show.  Even standing on my tip toes and leaning in, the front edge just barely touches my hair so I won't be banging my head on this thing.  The front edge is also about 4" behind the spindle center line so hoist use in the future for loading won't be a problem.I need to do a bit more welding, then some prep work and paint.Last pic shows the head stock back splash intended position.  It's about 12" tall by 18" wide.  A lip will be added to it also.What kind of paint will hold up to brake cleaner?
Reply:That looks good boostin!  I use rustoleum brush on on my lathe and haven't had any kind of cleaners take it off yet. Pretty decent chip resistance as well.The latest pic I have, paint still there after being coated with all kinds of different oils and cleaners for the last couple years.
Reply:I think I'm winning.... Attached ImagesMy name's not Jim....
Reply:lookin good Do you have to use a chuck guards in your state?  We had to install them a few yrs ago, they suck..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Chuck guards do they have bages and guns???
Reply:No, they flog you when you leave the chuck key in.... .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by Fabn4FunUs woodworking hobbyists had a problem with fluorescent lights close to the lathe work area.  The 60hz flicker would make the spinning workpiece look like it was writhing or undulating and hard to focus where I was hand feeding the chisel into the work....
Reply:Some paint and got it mounted.  Color is close with Rustoleum canvas white.  We'll see after it fades and gets dirty how well it matches. Attached ImagesMy name's not Jim....
Reply:Walmart has some halogen desk lamps with a 12" goose neck base for fairly cheap.  I have one on my lathe I modified to shine an intense light to the work area.  On yours you could use two of them to get light coverage over the full length.  I took the base off & mounted the goose neck to a short piece of angle.  It has a small switch inline with the power cord, which would allow you to turn one or both on/off.Walmart Halogen Desk Lamp Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:If you could put a vent van in the top of it you could get rid of the oil smoke when you are turning heavy.  Mac
Reply:Looks great!  Spin some oily metal and it will match well!Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by MondoLooks great!  Spin some oily metal and it will match well!Originally Posted by BoostinjdmSome paint and got it mounted.  Color is close with Rustoleum canvas white.  We'll see after it fades and gets dirty how well it matches.
Reply:Originally Posted by SandyLooks purdy now. That light color should help bounce the light around and cut back on shadows a bit.
Reply:Yeah light!  I got a replacement drill press light and modded it to work on my lathe with halogen bulb. I believe the light is for a craftsman drill press but am unsure.
GMT+8, 2025-12-27 16:40 , Processed in 0.116749 second(s), 18 queries .
