Skid steer pallet forks
发表于 2021-8-31 23:18:36 | 显示全部楼层 |阅读模式
Of course this would have never happened if they were used for their intended purpose. But C'mon, who doesn't "get the job done", when you have to? Yep, prying up asphalt will do wonders. That's ok, because aside from the boss, I'm the only weldor in the shop. Well a couple of non-english speaking guys can imitate bird poop on steel. Well first I will heat it up with a propane rosebud. Then I will gouge out the crack and finally weld it up with 7018. More pics when I do the job."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manOf course this would have never happened if they were used for their intended purpose. But C'mon, who doesn't "get the job done", when you have to? Yep, prying up asphalt will do wonders. ...
GMT+8, 2025-12-27 16:39 , Processed in 0.459569 second(s), 18 queries .
