hose type ????
发表于 2021-8-31 23:18:35 | 显示全部楼层 |阅读模式
i need to make a small ft long hose to go from my tig torch adapter to the gas outlet on my syncro 250 since the smallest hose i could find was six feet i figured i would make one im trying to find out what is the right type of hose to use ??? i tryed searching inert gas hose and got back nothing but fitting anyone know the name ????350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:standard air line is what i use._______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:ha good idea i hadent even  thought of that350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:If you have the standard inert gas connections, your LWS should be able to make one up in any length you wantExperience is something you get right after you need it
Reply:Hello umahunter, if you have any lengths of oxygen hose(the green side if it is siamese) you can use this hose very readily for your purpose. It is definitely oiless and will work appropriately for your intended purpose. Best regards, Allanaevald
GMT+8, 2025-12-27 16:40 , Processed in 0.101725 second(s), 18 queries .
