Need some layout help.
发表于 2021-8-31 23:18:28 | 显示全部楼层 |阅读模式
I want to build a nose cone out of pipe but I've forgot how to figure out the cuts. Any help would be appreciated.
Reply:Here is what I would do.Start with tube diameter = DTube radius is then r = D / 2Decide how long you want the cone = hCalculate how far down the tube you need to cut out the triangles:  (h^2 + r^2)^.5(That is the square root of the h squared plus r squared)Then depending on how heavy walled the tube is you need to decide how many wedges to cut out.  Probably a minimum of 8.Mark the end of the tube in 16 places (or twice the number of sections)  Measure down the tube form every other mark the distance calculated above and mark.From each mark down the tube draw a line to the end mark on either side (makes a V)Cut along those lines and bend the remaining points in.
Reply:What is the diameter of your pipe?6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:24 inch, and thank you Fern.Last edited by Duckslayer74; 03-08-2014 at 01:39 AM.
Reply:My data only goes to 12 inch, but this is what I have.....hope it helps. Attached Images6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
GMT+8, 2025-12-27 16:46 , Processed in 0.145975 second(s), 18 queries .
