Stick restarts
发表于 2021-8-31 23:18:25 | 显示全部楼层 |阅读模式
Just wondering any of u could give any advice on doing restarts. Doing a hot pass on a vertical stick weld with a 2.5mm 6013, and keep getting slag traps most of the time I do a restart and end up having to grind these bits out which is costing me time.
Reply:Strike the arc a little ahead of where you need to restart and drag it back to where you want to tie it in.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugStrike the arc a little ahead of where you need to restart and drag it back to where you want to tie it in.
Reply:I'm at a training centre so we have to use 6013 for this, might spend a day doing hot passes keeping arc gap the same , I'm sure il get it right. Thanks for the advice
Reply:Yup restart above your stop and then start welding again.
Reply:Originally Posted by Murphy's lawYup restart above your stop and then start welding again.
GMT+8, 2025-12-27 16:42 , Processed in 0.098017 second(s), 18 queries .
