Ring roller parts
发表于 2021-8-31 23:18:24 | 显示全部楼层 |阅读模式
Hello  folks  I would like to build a ring roller ,where could I find the rollers? I will build the case and handle just need the rollers.
Reply:Try getting replacement parts and then using them in your "Knock off".I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Try http://www.swagoffroad.com/SWAG-Tubi...ller_p_51.htmlThey also sell heavy duty shafts with keys to prevent rotation.TOO MANY TOOLS & NO MORE SPACE
Reply:I went to a machine shop (amish) and had 2 made for me. 2" cold rolled steel with a 5/8 hole. Cost was very low. I already had one roller.Dave ReberWadsworth Ohio
Reply:Definately get something off the shelf.  Depending on type roller then the SWAG stuff is a good deal.Sent from my SPH-M830 using Tapatalk
GMT+8, 2025-12-27 18:43 , Processed in 0.451195 second(s), 18 queries .
