XMT 304 trips breaker!!
发表于 2021-8-31 23:18:23 | 显示全部楼层 |阅读模式
I just picked up an XMT 304 in non working condition. The guy said it wouldn't power on, so the first thing I did was check wiring. The plug was wired incorrectly so I fixed that and tried the machine. Nothing. Then I tested the switch, it's fried.  Bypass the switch and use the circuit breaker for the switch.  It instantly trips the 30 amp breaker. It appears to have a new power board, but obviously something isn't right or isn't wired correctly. Any suggestions or does anyone have a technical manual PDF for this machine??? (Not the owners manual, I have that.)Sent from my iPhone using TapatalkWe offer correct, cheap and fast. Pick two.Weldanpower G800XMT 304Syncrowave 250Millermatic 135Maxstar 91Heliwelder 4A/DDR 224/HPA/BHFT Plasma
Reply:There is a thread in the Miller section covering this situation:http://weldingweb.com/vbb/showthread.php...turned-on-Help!The same person also has a thread on Miller's board.JohnLast edited by Silicon-based; 03-09-2014 at 08:52 PM.Reason: Add linkA few weldersA lot of hammersA whole lot of C-clamps
Reply:Thanks!Sent from my iPhone using TapatalkWe offer correct, cheap and fast. Pick two.Weldanpower G800XMT 304Syncrowave 250Millermatic 135Maxstar 91Heliwelder 4A/DDR 224/HPA/BHFT Plasma
GMT+8, 2025-12-27 16:47 , Processed in 0.105974 second(s), 18 queries .
