updated: Rusted strut repair
发表于 2021-8-31 23:18:22 | 显示全部楼层 |阅读模式
Here is the original thread if you MODS want to merge them   http://weldingweb.com/vbb/showthread.php?t=152521I finally started to tear into this project. I seen that where the strut mounts up top, there were pinch welds so I figured that plate would come off.....So I started drilling with some good ole carbide bits after I removed the struts. My question now is, Should I make a patch (like the cardboard peice) to butt up to the existing metal, or should I cut out the old metal and patch the new in (like a butt joint)? If I just butt it up against whats already there, it may lower my mounting holes for my strut a little. Attached Images
GMT+8, 2025-12-27 16:46 , Processed in 0.074812 second(s), 18 queries .
