Thanks for sharing your design with us Denny. I called this a tribute build because I normally just start with an idea I see and go from there, but your design was perfect for my needs. So I just copied it. Now that I have used it I really do like your design.Scott Attached Images
Reply:I also built a outlet table support and cut length stop, more copying. LOL Attached Images
Reply:Just a few more pictures, and I even copied you clamp fixture for cutting box tubing. What can I say, Thanks Denny. Attached Images
Reply:That looks great.
Reply:Hey Harley,Thanks for the acknowledgement bro'. I appreciate you finding the design would be useful to your needs.You did a GREAT job! The other fellows who also used the design to make their own also felt the space-saving was really important as the stand has a small footprint, yet was full function. Kudos to you Harley......DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Beautiful and functional. This is one of my goals this summer is to make several of these carts for the shop.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Wow.....nice work on the part of the designer and the fabricator. I love how that square tubing can be used to make things that "transform" then fold back up....
Reply:I totally concur with you Harley on your comments on Denny's design. I"ve been using my copy of his chopsaw stand for a couple of years now and I thank him every time I use it.You have done a great job on yours. Nice paint job. I particularly like the contrasting colours.I have yet to build the square tubing cutter jigs but they are on my list as well.Anyone else that builds this will find themselves asking why they hadn't buiit one a long time ago.Thanks again Denny for sharing and kudos to you Harley for such a nice build and for sharing.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Originally Posted by HarleyscooterThanks for sharing your design with us Denny. I called this a tribute build because I normally just start with an idea I see and go from there, but your design was perfect for my needs. So I just copied it. Now that I have used it I really do like your design.Scott
Reply:X2 Here for big thanks to Denny for his design.I also use mine a heck of a lot. I do a lot of pipe cutting and it is a real pleasure to use mine. It tends to want to tip over though. Can't understand that I only have a 25 foot piece of 3 inch pipe on it....why should it want to tip......I really like your little offset stand for your light.One item I still have to add is a place to keep my mechanical pencil with the silver lead in it and my tape measure.Great job on your build!!Denny, any progress on the bender?Glenn.Sign on East Texas payphone: Calls to God 40 cents......it's a local call... |
