Fixing the Demo Saws...
发表于 2021-8-31 23:18:20 | 显示全部楼层 |阅读模式
We have 2 STIHL TS400 Demolition saws... Our older one has had a cracked guard for some time so I decided to bring it home and button it up... I also made a new handle to adjust the guard as the original one broke.Welding the guard was tough because it is 2 pieces riveted together -- the closer you get to the other piece the more hear it was drawing and my welds started to look a little cold and bird-s##tty.Now I need to replace the mufflers on both but we waited so long the bolt heads rotted... Grrrr now I need to take both saws apart to get them off...Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Ha, good repair.  Ive got the same model saw( bit older 1999) with the same crack in my guard.  Priced a replacement and thy wanted around $250-$300.  or he said he could weld it for a lot less.  Hey i weld.  So its been on my to do list for quite some time and now seeing your has motorvated me to do mine, except i wont have time till the weekend.
Reply:Post pics when it's done!Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:If it ever breaks too much to fix you can get aftermarket guards on ebay for like 40-70$ depending if you run a 12" or 14" wheel.
GMT+8, 2025-12-27 16:31 , Processed in 0.256331 second(s), 18 queries .
