oxygen tank
发表于 2021-8-31 23:18:12 | 显示全部楼层 |阅读模式
my neighbor gave ma a oxy tank and i am curious about how much average it cost to have it hydro tested. i wanna use it in an oxypropane setup. he said it hasnt been done in about 10 years or so. its probably waste high and about 6 inches around.Zach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:In the front of the general welding section there is a link to a welding tank size list.  You should look up the size of the cylinder then phone your local welding supplier.  If there are any decals on the cylinder it may indicate where if came from.
Reply:Originally Posted by lotechmanIn the front of the general welding section there is a link to a welding tank size list.  You should look up the size of the cylinder then phone your local welding supplier.  If there are any decals on the cylinder it may indicate where if came from.
Reply:Originally Posted by midGAoutdoor its probably waste high and about 6 inches around.
Reply:thank you all for your help.Zach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
GMT+8, 2025-12-27 16:47 , Processed in 0.105624 second(s), 18 queries .
