Lincoln Excalibur 7018 on AC?
发表于 2021-8-31 23:18:06 | 显示全部楼层 |阅读模式
I though Lincoln Excalibur 7018 could be ran on AC. I guess I thought wrong. It runs for about an inch or two then cuts out, I tried 110 amps up to 170. But no go.Hobart Stickmate LX 235 ACEverlast Powerarc 140ST DC InverterPowcon 300ST
Reply:Hello Jeffvador, even though E7018 electrode is listed as an AC/DC electrode I know of very few people who have good luck running it on AC. When you look at the spec. you'll notice that DC is listed as the primary recommended current and AC is secondary. Of the folks I know that run it on AC many of them are using high-frequency stabilizers to assist with the "arc outage" that you are experiencing. You might try the E7018 AC rods that are manufactured by a few of the rod providers, they have some additives in the flux to assist with the arc problem. Good luck and best regards, Allanaevald
Reply:Probably not holding your tongue in your mouth right - try sticking it out the left side  Or you didn't buy the 7018ac version.http://www.lincolnelectric.com/Catal....aspx?p=109019Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Never tried Lincoln Excal on ac current,,, but I tried Hobarts regular 7018 on ac,,, ya not so much.... Hobarts AC7018 run pretty smoothTOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:I played with Lincoln's Excalibur 7018 with a 1970s buzz box. Only thing I noticed is, it doesn't wet out like on DC. Rod right out of the over did wet out better than rod that had never seen the inside of a rod oven. The arc never went out on me once. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I had one of those CEP, it was AC only though - underrated nice cheap welder in my opinion.It's still serving duty on a farm right now. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I bought that machine in 1977 I think. Seems like I paid a couple hundred dollars for it. Still have it, it's back in a corner of the shop. Use to do a lot of Tig welding with it.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPI bought that machine in 1977 I think. Seems like I paid a couple hundred dollars for it. Still have it, it's back in a corner of the shop. Use to do a lot of Tig welding with it.
Reply:Originally Posted by MinnesotaDaveI was 7 then
Reply:Originally Posted by MinnesotaDaveProbably not holding your tongue in your mouth right - try sticking it out the left side  Or you didn't buy the 7018ac version.http://www.lincolnelectric.com/Catal....aspx?p=109019
Reply:77....77....77.... Was that a year ? OH ! OK !!! Seagram's 77 !Can't remember who played lead tho Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by kctgbDo you remember the pic I posted of a welder just like yours I found free on the side of the road last summer. After cleanup it runs very well, I use it sometimes for repairing farm equipment.
Reply:Originally Posted by aevaldHello Jeffvador, even though E7018 electrode is listed as an AC/DC electrode I know of very few people who have good luck running it on AC. When you look at the spec. you'll notice that DC is listed as the primary recommended current and AC is secondary. Of the folks I know that run it on AC many of them are using high-frequency stabilizers to assist with the "arc outage" that you are experiencing. You might try the E7018 AC rods that are manufactured by a few of the rod providers, they have some additives in the flux to assist with the arc problem. Good luck and best regards, Allan
Reply:Originally Posted by CEPI played with Lincoln's Excalibur 7018 with a 1970s buzz box. Only thing I noticed is, it doesn't wet out like on DC. Rod right out of the over did wet out better than rod that had never seen the inside of a rod oven. The arc never went out on me once.
Reply:Gee CEP, I do remember that and I am old too! HEH, HEH, HEH. Just funnin' ya!aevald
Reply:Originally Posted by CEPCan we get an icon of someone giving the middle finger?
Reply:Originally Posted by JeffvadorThat's crazy man, I just couldnt keep it going to save my life. How many amps did you run?
Reply:Originally Posted by JeffvadorI have a couple lbs left from a 5lb box of those 7018 ac. I just grabbed a handful of the excals from school to try at home.
Reply:CEP, your memory can't be any worse than mine, I burned my first stick in 1979.
Reply:Originally Posted by kctgbCEP, your memory can't be any worse than mine, I burned my first stick in 1979.
GMT+8, 2025-12-27 16:47 , Processed in 0.106266 second(s), 18 queries .
