Bending wide sheet at home
发表于 2021-8-31 23:18:03 | 显示全部楼层 |阅读模式
Anyone have any quick, down and dirty ways to bend a .125 alum sheet to a 45 at home?Its 92" wide.Maybe relief cuts, and re weld?A friend has a break, but it will only do 6' of .125.  In your experience, if i was to cut reliefs into it, would it bend?
Reply:Here you go...http://weldingweb.com/vbb/showthread.php...ithout-a-BrakeDenny does it with the table saw, but you can do it with a hand held saw and guide if you are careful and take your time..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:How did i forget that thread.Thanks doug.
Reply:Most aluminum alloys will crack when bent. 3003 or 5052 normally bend good.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:I did not even think of that.  Dang.  Its 6061.....
Reply:6061 will bend as well but likes a bigger radius and normally not a tight bend.
Reply:Anneal it with an acetylene flame. Black it with acet. Heat with a rosebud(at a distance) when the black goes away you can fold it like a towel.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Do it in one shot. Bend it twice and all goes to sh!t. Aluminio is strange.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by BurpeeDo it in one shot. Bend it twice and all goes to sh!t. Aluminio is strange.
GMT+8, 2025-12-27 16:41 , Processed in 0.365609 second(s), 19 queries .
