fishing gaff
发表于 2021-8-31 23:17:58 | 显示全部楼层 |阅读模式
Millermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:you should ad some more flat to go all the way around in that set up you're more likely to split the wood out because there is no support in the direction of the hooking motion.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Oh yeah.  Whatchya gonna gaff, ifn ya git so lucky? Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-27 16:42 , Processed in 0.110823 second(s), 18 queries .
