bobcat 225 plus oil pan
发表于 2021-8-31 23:17:57 | 显示全部楼层 |阅读模式
I boght a bobcat 225 plus with a cracked oil pan so after some preheat and grinding of the cooling fins to get to the crack i welded it back up Attached ImagesIf it don't fit, use a bigger hammer, if it breaks it needed to be replaced anyhow.
GMT+8, 2025-12-27 16:42 , Processed in 0.082014 second(s), 18 queries .
