Broken Hilti Bit
发表于 2021-8-31 23:17:51 | 显示全部楼层 |阅读模式
So I had a broken bit and now I have a third hand.Just figuring out how to post a pic.....and yea I had to cover up the original bead with two beads because I didn't realize how much heat I really needed to puddle up that tool steel. Attached ImagesHow do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:I don't know watchyamade, but the welds look good.  3 consistent passes.  Both sides?Spill the rest, tungsten, filler......David  Real world weldin.  When I grow up I want to be a tig weldor.
Reply:So it's a third hand do-hickey for holdingstuff down to get a tack on it. Thanks but I've only shown the decent welds. The one underneath just laid rightup on top of the tool steel without a good bond. And the ones on the other side.... um, yea, well, you'll see.Ended up being dcen about 190 amps with 3/321.5% lanthanated, 3/32" filler, #7 cup, and trying not to burn through the 1/8" flat stock that I puton because it makes it makes it a little easier to put the work clamp on.Just using up scrap and trying things out. I really wanted to see how to post up a pic.So here's the ugly other side of it too... Attached ImagesHow do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:I like it.   I doubt the ground shark fin thing will ever come off.   Is the last picture the second side? DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Yep, second post is the 'dirty' side!How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:I asked because it looks like the piece was already hot when you started the side. No thing like the first side.Make another one.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Yeah I wouldn't of seen that (or thought of it till you mentioned it) but you're right.The ugly side was first and then the good side after.Good eye.That freaking thing was hot for almostan hour afterward too.How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:i call that thingy a welding finger.. nice..but what  does it have to do with broken hilti bit?
Reply:Originally Posted by weldbeadi call that thingy a welding finger.. nice..but what  does it have to do with broken hilti bit?
GMT+8, 2025-12-27 16:39 , Processed in 0.072254 second(s), 18 queries .
