how do you remove a Perkins from an SA250
发表于 2021-8-31 23:17:48 | 显示全部楼层 |阅读模式
I've got 2 sa 250's, one with bad generator, on with a bad motor and I'd like to switch the good motor into the good generator. Can't see how to remove the motor from the generator. Can anyone help me out? TIA
Reply:Where you located?
Reply:Long process,  requires complete disassembly of the generator to separate the twoSent from my SGH-M919 using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Long process short start at end opposite of engine and start removing almost all bolts and wires and housings
Reply:Originally Posted by spooled05Where you located?
Reply:Yeah before you start tearing apart anything get you a copy of the manufacturing manual to aide and guide you. Once your in your in, there's no going back. Bills weld repair has most manuals~1987 Lincoln Sa-200~~1978 Miller Big 40~ (restored) ~and everything inbetween~
Reply:And don't be a damned fool either. Use a camera and take a lots of pictures while you are taking things apart, BEFORE you take stuff loose.That way you sort of have a map of where everything went, and how it went.You'll be thankful if you do, and hate yourself if you don't.
Reply:If you cut a few 1/8" gaurds on the generator housing you can reach in and unbolt the cooling fins on the flywheel and then untwist the flywheel from the generator stands and take it off very easy. I doubt I have pics from the last time I did one.
Reply:That's how I ruined a good machine, nicked a shunt coil. Had to disassemble the RIGHT way to fix it. Sent from my SGH-M919 using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Originally Posted by kkustomzIf you cut a few 1/8" gaurds on the generator housing you can reach in and unbolt the cooling fins on the flywheel and then untwist the flywheel from the generator stands and take it off very easy. I doubt I have pics from the last time I did one.
Reply:Originally Posted by greggvI've got 2 sa 250's, one with bad generator, on with a bad motor and I'd like to switch the good motor into the good generator. Can't see how to remove the motor from the generator. Can anyone help me out? TIA
Reply:Yes I have done one that way, I was probably 18 years old when i rebuilt the perkins on it and its still going and generating power just fine.
Reply:I don't doubt it does work just fine.  Cutting it up is just not the right way to do it IMO is all.  Kinda like taking a holesaw to your car's fender so you can take the sparkplugs out so you don't have to open the hood.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Just about everybody that owns an old 200 knows you CAN cut the guards on the stator but it is a half assed way of doing it but much quicker. Do yourself a favor and take it apart the right way. Rebuild the wore out generator. Work on the other one later. You will understand these much better if you do it the right way.
Reply:Originally Posted by duaneb55PM me an email address.
Reply:Try it again.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-27 17:08 , Processed in 0.142744 second(s), 18 queries .
