Threaded Inserts..Washers..Tiny Welds..
发表于 2021-8-31 23:17:42 | 显示全部楼层 |阅读模式
Had some threaded inserts that needed "Stop" washers welded to them..Keep it small and "Don't wreck the threads"...Positioner in use.(Be sure to get all the zinc coating off the washers........)Parts..Tacked..In The Positioner..Welded..Batch done..I have probably done a few hundred of these by now..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very cool, did you add filler rod or just fuse them? They look good.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Reply:You get all the good jobsExcellent workBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Amazing the difference is size of things that moves through your shop!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by bhardy501Very cool, did you add filler rod or just fuse them? They look good.
Reply:You must have needed the good glasses, at your age and alll Happy late B-day, see you Saturday morning.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:2nd pict looks like the tack in the upper left got down into the threads some. Did these all check out with a bolt?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Zap, that is some delicate excellent work.  I'm not that steady. Congrats.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:That is amazing
Reply:What size tungsten did you use?miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Originally Posted by turbocad6What size tungsten did you use?
Reply:Originally Posted by DSW2nd pict looks like the tack in the upper left got down into the threads some. Did these all check out with a bolt?
Reply:Originally Posted by TozziWeldingYou must have needed the good glasses, at your age and alll Happy late B-day, see you Saturday morning.
Reply:Anytime I want to know how bad I am at welding I just look at your work.Unbelievable!!!!Would love to meet you someday..From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:Zap you are one hell of a welder. I love learning from your work. keep it up Bro!!!!I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:IFYOUTHINKHARDENOUGHYOUCANFIGUREANYTHINGOUT    no spaces?miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Originally Posted by jdchmielIFYOUTHINKHARDENOUGHYOUCANFIGUREANYTHINGOUT    no spaces?
GMT+8, 2025-12-27 17:08 , Processed in 0.137686 second(s), 18 queries .
