diamond plate / tread plate costs
发表于 2021-8-31 23:17:39 | 显示全部楼层 |阅读模式
What kind of prices are you guys paying for 4x8 sheets of 16 ga and or 14 ga diamond plate aluminum? Been looking online but no prices are listed.
Reply:4'X12'X 16ga  Aluminum floor plate, $179Seems to only be available in 4' widths, 8',10, and 12' longAllMetals, California (oroville)
Reply:Thanks bart , i like kicks prices better but id say shipping would get me from down under! Been thinking about building  toolbox for my tractor and i know that usually you pay less per sq foot with a whole sheet than buying in individual small pieces. Im going to check with my local steel supplier to compare , thanks!!
Reply:4x8x.125 $118. 4x8x.063 $68
Reply:voodoo what series and where are you getting that quote from? pretty good prices. A sheet of 4x10 3003 3/32 ran me $175 out the door (non diamond plate)
Reply:Yea no doubt voodoo is getting a good price! BC  , what does 3003 series mean? I think in aluminum there are different hardness ratings as in some can be bent over 90 degrees and some can't , right? Thanks for the replies.
Reply:It's what aluminum is alloyed with. If you are planning on using a brake to bend it, go with 3003. If you plan on using it in corrosive environment(marine) go with a 5000 series. If you do plan on bending, that will put out 6061 since it will crack. You can also get some sheets in alclad which has a thin layer of pure aluminum on the outside that will polish up nicely and provide corrosion resistance. Just google "aluminum series" and you'll find a wealth of info. 2000 and 7000 series are generally deemed non weldable and are used extensively in aircraft(2024 in wing skins and 7075 in Firewalls, etc), as is 6061.
Reply:3000 series. I buy my aluminum from Eastern  Metal Supply (EMS).  I get a lower price because of my account activity and then I always ask if they can do a little better and the knock off another 10-20% like its nothing. Make you wonder what their costs really are......
Reply:Also I am referring to diamond plate, not flat.
Reply:thanks again guys , good info. I am going to be tig welding the corners and bottom.If you use the 3000 series  , what aluminum rod / alloy (tig) would be best or does it matter?
Reply:3003 plate you can use 1100 or 4043. Thought not always recc I will also sometimes use 5356 if I anodize it and need some strength. But for your application, 1100 or 4043 would do the trick
GMT+8, 2025-12-27 17:08 , Processed in 0.162747 second(s), 18 queries .
