Do this next time....
发表于 2021-8-31 23:17:36 | 显示全部楼层 |阅读模式
Next time your at the LWS, or any store that sells batteries, buy another set for your auto dark helmet.....I don't have another set and was all set up to strike an arc at my brothers house, but..... my batteries are dead and I don't have another helmet here.Next time I'll have another set in my helmet bag.
Reply:Or just keep a old fixed lens as a backup If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:The only issue I have with buying "spare" batteries, is that many will go bad just from sitting if stored under improper conditions.That said, I usually buy a "spare" set after 8-12 months of use and rotate to old spares into the device. There is a definite advantage to having a hood that uses "standard" batteries like AAA's rather than "specialized" watch batteries, especially if you work odd times when you may not simply be able to run out and pick up a spare set.I do however also keep my old fixed shade Jackson as a backup in the truck for class, since I've had the AD hood die on more than one occasion..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:None of my 3 AD helmets use batteries.My name's not Jim....
Reply:I keep an old TV remote on the welder so I can check the helmet. Press any button on the remote and it should darken... if not... time for batteries (in the helmet not the remote  ).Having more than one helmet is the key. Also,  a spare helmet is great for when the wife or friends drop by the shop... they can watch and you can keep working.
Reply:Originally Posted by BoostinjdmNone of my 3 AD helmets use batteries.
Reply:Regarding the batteries staying fresh, I keep my back-up small batteries in the used pill containers from prescriptions.  They stay fresh as these containers are air tight. Just food for thought.   Bob
Reply:Some higher quality hoods have a low battery indicator.Yea right, mine went on JUST A MINUTE BEFORE IT DIED!
Reply:Originally Posted by walkerNot true, they just don't use batteries that you can get to.
Reply:I got a little blue medicine box in each truck with two sets of spare batteries.  We got like 8 miller elite helmets and a few fiber metal pipe liners with gold fixed lenses.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Originally Posted by larpheadOr just keep a old fixed lens as a backup
Reply:Walgreen's are everywhere and carry my size.. I feel for the folks in the sticks though14' PowerMig 210 MP13'Burntables 5x10 CNC Table14' SAE300 HE on a 12' Ram 4500 60 CA 4x4. Custom bed/bottles/reels.87' SA250d, 78 SA200,11' Ranger 250 GXT AC/DCThermal Dynamics Cutmaster 8112' Lincoln Precision Tig 22508' LN25
GMT+8, 2025-12-27 17:17 , Processed in 0.070301 second(s), 18 queries .
