Maxstar off a gen...
发表于 2021-8-31 23:17:35 | 显示全部楼层 |阅读模式
I have a little Maxstar 150.  One of the things I have loved about this tiny inverter is how portable it is, not just in size and weight but the fact I weld 1/8" mild steel off a 110vlt 15amp circuit. It generally doesn't blow a 15amp breaker till around 100amps for a few minutes.How would it run off 5500watt gen? Is there much risk to an inverter welder when plugged into a gen? The gen is a rental, not to be an *** but I'm not  too worried about it.
Reply:I ran my maxstar 150 off of my bobcat 250.  I had 300 ft of 12 gauge, 120v extension cord plugged into one of the 120v outlets on the machine.  I was well below the 100 amp mark on the dial of the maxstar, but that little booger sure did get me out of a jam!  I eventually made a pig tail -a 220v male with 120v female. the maxstar can't tell the difference.  that way you can get enough juice to the maxstar and not worry out blowing fuses.  Good luck !
Reply:Should work no problem.  I do that too, but I use 220 so it has plenty of power.   Most generators have 220.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by UpnorthI have a little Maxstar 150.  One of the things I have loved about this tiny inverter is how portable it is, not just in size and weight but the fact I weld 1/8" mild steel off a 110vlt 15amp circuit. It generally doesn't blow a 15amp breaker till around 100amps for a few minutes.How would it run off 5500watt gen? Is there much risk to an inverter welder when plugged into a gen? The gen is a rental, not to be an *** but I'm not  too worried about it.
GMT+8, 2025-12-27 17:17 , Processed in 0.076884 second(s), 18 queries .
