Any Better?
发表于 2021-8-31 23:17:32 | 显示全部楼层 |阅读模式
I have a line in some of the welds? But over all an improvement ?Sent from my iPad using Tapatalk
Reply:Not bad. 1st pict bead on the far right looks a bit fast. 2nd pict hard to really tell much, but the far left one looks cold.It would help if you list machine settings, material thickness, wire size and type so we don't have to guess. I'm sure you have in other threads, but I can't remember... This info helps when trying to make suggestions..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWNot bad. 1st pict bead on the far right looks a bit fast. 2nd pict hard to really tell much, but the far left one looks cold.It would help if you list machine settings, material thickness, wire size and type so we don't have to guess. I'm sure you have in other threads, but I can't remember... This info helps when trying to make suggestions.
Reply:Far left bead 1st pict looks pretty good. Center bead isn't too bad, but a bit narrower than the left one at the beginning. As mentioned the right bead has those triangular shaped ripples that usually indicate travel speed is a bit fast. If you could do a few more consistently like that I'd say start doing overlapping beads and see how your aim is. If those go well we move on to laps..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-27 17:17 , Processed in 0.098885 second(s), 18 queries .
