New use for empty wire spools
发表于 2021-8-31 23:17:25 | 显示全部楼层 |阅读模式
Figured out a way to recycle the empty 10 lb wire spools. It works really well for string line. 2 1/4" hole saw cuts a plug that will drive in to spool center. One of 1 1/2" and one of 3/4" wood. 5/16" carriage bolt for the axle and 3/8' carriage for the crank.                                         MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I like it!! I hate wrapping line around a stick, rock, or whatever happens to be closest to the work...Now i just need to get a MIG welder haha.... all i got is TIG and Stick.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:That need some refining... it needs a free spinning handle (so you don't booboo your hands when useing it). Good idea though.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:whats with the winding handle? why not just stick the allthread into a portable drill? and use your free hand to guide the line onto the spool. Tighter winding, cleaner look, and less hand work. Just a thought.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerwhats with the winding handle? why not just stick the allthread into a portable drill? and use your free hand to guide the line onto the spool. Tighter winding, cleaner look, and less hand work. Just a thought.
GMT+8, 2025-12-27 18:43 , Processed in 0.074190 second(s), 18 queries .
