tig wleder
发表于 2021-8-31 23:17:21 | 显示全部楼层 |阅读模式
where can i get a nice lincoln or miller tig wleder for cheap?
Reply:Sorry Moe, The words miller,lincoln and cheap dont flow together. Check craigs list someone may need to turn some coin quick..
Reply:yes i did alot lol whats a good mig welder i can also set up for tig?       http://www.lowes.com/pd_2961-1703-K2...der&facetInfo=
Reply:I'd suggest you try wearing out the search feature.My name's not Jim....
Reply:Unsure.about it??  I know tig welders are expensive but get a good one!!! dont buy any chink stuff from HF or someother low-end place. You will so... thank yourself later.
Reply:my buddy will sell me a barely used miller mig/tig welder, just has no leads its about a year old or so. he wants 1500 for it? good deal or no?If the conversation isn’t money, then I’ll see you later.
Reply:Migs and Tigs don't usualy go together.   Mac
Reply:In order to estimate the value, you are going to have to post a model number.
Reply:her is a link for craigslist so you cna check a larger area.  You put in your location and how far you will go and it shows any sale within that distance.have funTom
Reply:Originally Posted by MOE1my buddy will sell me a barely used miller mig/tig welder, just has no leads its about a year old or so. he wants 1500 for it? good deal or no?
Reply:A DC tig rig is cheap if you have a power source and don't need to weld aluminum.  my weldcraft 200 torch was less than $300 (new) in 2008.  prolly more than that now tho.  If I was starting out again, id  get me an Lincoln AC/DC Idealarc 250 and a DC tig rig.  Get proficent at stick and tig'n, everything else will be a breeze to pick up !
Reply:I second the craigslist idea. That's where I found mine.Syncrowave 250MM130
Reply:MOE1 doesn't post where he's at, but a guy on Craigslsit in Mukwonago, WI had a nice vintage Miller Tig/Stick machine, Industrial AC/DC machine, quality that will outlast you.He wanted $700
Reply:I'm in ma option gonna buy my buddies after reading ya guys comments he told me it has less than 15 hrs. Model # soon!If the conversation isn’t money, then I’ll see you later.
Reply:Moe,Take a welding course first.  Save that $1500.Before Christmas there were at least 2 xmt 304s for around $1100 in Maryland.  Have no idea what they finally went for but I saw them on Craigslist for at least a month.First you have to know what you want.  A multi-process welder for $1500 with no cables, is in fact a very expensive, DC only stick welder.  To make it MIG, you need to add a wire feeder that even used, is going to run $500 or so.  Add gas handling (something to hold bottle and regulate gas flow + bottle itself - and pretty soon your have another $500.  As for TIG, without high frequency start, its not going to be much of TIG machine.  If you can find a high frequency unit, you still have to add torch, +  gas etc.  Call it $800.  Oh, and you can drop $100 on leads easy.  Copper is expensive and quality leads tend to be thick copper.If you really want a TIG machine (how do you know?), your probably better off looking at either a Maxstar series or syncrowave.  If your willing to toss $1500 into the wind, you should probably save up another $1000 and look for a used Dynasty (see ebay).Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:i did the welding class, well still doing it, i wanna mainly do tig for bike things.If the conversation isn’t money, then I’ll see you later.
GMT+8, 2025-12-27 18:41 , Processed in 0.128882 second(s), 18 queries .
